Hello from a long time reader of these forums, I'm planning to move the USVI in a few months to break ground on a retirement home.
After several visits spanning several years to plan the construction and reading these forums I have a couple of questions.
Previously there was a cap on new grid tie installations, I understand that new connections are being allowed again since 2016.
Electricity is expensive running about .32 to .34 KWH from the VI power company WAPA. Second a lot of home do have solar installations, but almost all are grid tied. WAPA is not the most reliable power supplier on a good day either, normal wind or rain storms will interrupt the power on the island. Current sun hours run about 5.5 to 6 hours per day.
Some island solar installations have generators with grid disconnects, several friends with solar have been on generators since Maria hit the islands in September 2017 until just a few weeks ago.
Currently this is what I have come up with so far, daily home power usage would consist of two refrigerators, cistern pump and pool pump as the major loads. smaller loads would be the LED TV's and lighting.
Additional loads would be four 5000 to 10000 BTU a/c split units.
Plan the electrical service during the construction to allow the installation of solar grid tie, battery back up and generator back up? rather then adding later as needed?
Size the battery and generator to the electrical loads less the a/c split units, taking those off line when the power is interrupted
Hook up to the grid and watch the actual usage over several months and size the PV system at that time?
Current roof design allows for 20 standard panels minimum.
Would prefer a bullet proof system that is easy to service and upgrade the electronics. Panels would need to be wind and storm rated for HVHZ. 150 MPH
Would a "Power wall" type battery installation be a better choice for energy storage if the grid is down for several days to weeks rather than running the generator all the time?
Just thinking of the cost per run hour "Power wall" vs generator when the grid is down for days to weeks.
If the forum could help with a rough idea for a PV system and then I can get some quotes from the local contractors to see what they are recommending for panels and inverters.
Thanks for any thoughts,
