I have a solex system and run a lg chem 6 4 battery its full by 10am and i put about 27kwh into the grid now .can i run a second battery i have 6.2kw of panels .and fill my exiting battery early and get 6c a kwh for my 27kw back to he grid .can i run 2x6.4lg chem side by side
Can you run dual lg 6.4 battery
Hello shanew and welcome to Solar Panel Talk
Your question is a little hard to understand. Also you haven't told us where you live and what your POCO will allow concerning the system you are describing. -
Yes a lg chem battery 6.4exb is what i have now .im in northern new south wales australia i have a very good system now but my batteries are full by 10.30 am and i put 27kwh backn the grid at 6c a kwh so i want to put a second battery on the system i haveComment
then you certainly could use some of that power to recharge a 2nd LG Chem RESU Battery Bank.
Are dealing with a Time-Of-Use cost issue or do you need more Battery Power at night?Comment
Hello
I have not found how to publish a new post, I have a battery LG M48126P3S, but does not work, someone knows what the errors shows with the LEDs
ThanksComment
If you have not called them, why not ?
Did you check the manual(s) ?
What did you glean from the manual(s) ?
Still under warranty I suspect ?
If you have not called the mfg./installer, why are you asking questions on an semi anonymous forum of mostly DIYers when professional help from mfgs. and installers is only a phone call or an e-mail away ?Comment
I answer in the last message
What have LG and or the installer told you when you called them ? the seller send another battery, but not collect the old battery
If you have not called them, why not ?, the seller send another battery, but not collect the old battery
Did you check the manual(s) ? in manual not say nothing for the lights error
What did you glean from the manual(s) ?in manual not say nothing for the lights error
Still under warranty I suspect ? old battery not under warranty, seller send new one
I was interested to know what happens to the battery, next step is destruction
A quick Internet search suggests that you can paralell as many as 10 LG Chem RESU batteries. Check manual for details.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
