I erroneously posted this on a sticky and don't know how to remove it so I'm posting it again. Please accept my apologies for double posting.
I am in need of guidance to help a friend who lives overseas in a country where grid power outages are quite common. All systems run on 220V AC. He has had a battery backed 8kW PV system with 4 inverters which would switch to backup power when grid supply went down.
Recently, the utility has started offering net metering and he wants to know if it makes sense for him. His vendor has proposed a single SMA10000TL inverter with SMA WebConnect module for net metering setup. He is told that his existing system will work as Backup system (UPS) where the PV will be attached to Grid Tied Inverter.
I'm not sure how it will switch in the existing system as a backup. The single line diagram (attached) they have provided doesn't show any link with the existing inverters and batteries. Is SMA1000TL a hybrid inverter and should the system look something like the second diagram?
