Hi everyone,
I've been doing a lot of research into solar systems, and I have determined the following things:
- My roof will support (just barely) 24 panels of solar panels
- 16 panels will be south-west facing, 8 will be south-east facing
- Parts of the roof will be shaded in the morning and evening due to trees on neighboring properties
- I currently use about 500 kWh of power per month (16.67 kWh / day on average)
- I want to be grid-tied, but maximize the in-home use of the power coming from the panels and sell extra power back to the grid (I don't trust the POCO to keep their current rates/policies, and who knows what future prices are going to be like)
The system I have designed so far:
- 24x SolarWorld SW 345 XL Mono panels (in 6 groups of 4 panels in series)
- 1x Outback GS8084A Inverter (with Mate3 controller)
- 6x Morningstar TS-MPPT-30 charge controllers (with networked meter and temp probe)
- 48v 400 Ah NiFe battery
From what I've read for my area (Connecticut), these panels should produce at minimum 500 kWh / month.
For the batteries, 400 Ah at 48v and 85% inverter efficiency and a 80% depth of draw should be 13 kWh of power, which should be enough for most of an average day even without solar adding to it. According to the specs for this battery, it should be charged at C/4 (100 amps), though higher charging rates are OK as long as the electrolyte temp doesn't go above 115 F. The minimum charging rate is C/20 (20 amps), but has much lower efficiency. The 8000 Watt inverter can draw a maximum of 78.4 amps from a DC source; 8000 Watts / 120 volts / 0.85 efficiency is my calculation there. Therefore, if the charge controllers are all producing their max current (180 amps total), the batteries can charge at 101.6 amps and the inverter can be producing its maximum power. That part seems fairly balanced to me, anyway.
If you're wondering why I'm looking into 6 small charge controllers, rather than 2 larger ones: I've done quite a bit of research on the SolarEdge system, and I love how each panel gets its own MPPT unit to optimize power production. Unfortunately, their inverters have almost no capacity for working with 3rd party charge controllers or battery systems, so I'm attempting to emulate the strategy with other components. The 30 amp charge controllers have about the same price / amp as larger charge controllers once I add in all the combiners and whatnot, and the Morningstars I selected are extremely robust (no moving parts, solid state components) so they should last a long time, and replacing a failed one shouldn't be too painful.
I have considered other battery types like FLA, Lithium, even a Vanadium flow battery, and even with the high initial cost I really would prefer to go with the NiFe. The price (including racks, water treatment equipment and shipping) for the battery is around $18k. If the battery will typically produce 13 kWh of power (see above), then that works out to $1.38 / watt. Due to IRS policies on rebates for solar systems with batteries (essentially I can't charge it from the grid, which I'm not), I will be getting a 30% federal tax credit, as well as a 30% state credit (if I can get this installed before the end of the year). So the battery price will actually be $7200, which comes out to a much more reasonable $0.55 / watt of usable power, for the entire life of the system (25+ years). The other options had similar price points over that time period, but usually involved a lot more maintenance and effort.
So, due to my circumstances with the panel placement, I doubt I'll ever get the full 180 amps possible between the 6 charge controllers. According to the charging parameters above, I'd want 100 amps going to the battery, and any extra going toward powering the house or being sold to the grid. I'd also want to track power draw at night and only charge the batteries as much as they were discharged, which is something I'd expect a charge controller to be able to track. If the panels stopped producing enough power to efficiently charge the batteries, I'd want it to switch to converting it all to AC for house/grid use. If more power than the panels can produce are needed, it should then draw from the battery until an 80% DoD point is reached, at which point it can pull from the grid. I haven't done the math, since I don't know enough about the charging efficiency or the power buyback rates, but there has got to be a balance point where utilizing grid power vs charging the battery for night-time use has to make sense. I know I'm not saving money by getting a battery, but I am buying some insurance against a future where electricity prices spike and the POCO has lobbied for pricing policies that make fully grid-tied solar a bad choice. Eventually I'd like to get an electric car and install a ground source heat pump, at which point I'd need a lot more solar.
What I'd like to know is this: can the GS8084A track the amperage going to and from the battery and utilize any extra power for house use and/or selling to the grid? I haven't really seen any standard wiring diagrams for this kind of situation, so I'm not entirely sure which parts would be connected in such a way to gather the necessary data. Given the claims in the product details, it seems like what I want to do should be possible, but I'd like more feedback before I commit to buying anything.
Thank you!
Thank you!
