Hello, I'm from Brazil I'm sorry my bad English, I have a GridTie 1000w, 2 solar panels 260w, battery bank 6x 27ah in series and parallel to add 24v, batteries are were charged without connecting the gridtie by connecting the gridtie showed 500w production and after 2 minutes 24w, to turn off the gridtie batteries back about 12,2v, bad gridtie or bad battery bank?
Batteries run after two minutes
You would need to give us more information. How many DC amps were the PV panels producing into the batteries ?
500W of PV will not keep up with a 1,000 w inverter .Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I'd need to see a diagram of how you have all that wired together to understand your problem.
WWWComment
