I'm designing a battery backup system and wanted to get your thoughts. I use about 15,000 kWh/year, but am taking additional steps to reduce that (e.g. more LEDs, new variable pool pump). I figure an 8kW to 9kW system will get me to around 12,000 kWh, which I think will end up covering my use once I reduce some more. Here is the proposed system:
27 x LG Neon 320W Panels
1 x Radian 8048a with GSLC Load Panel, Mate 3 and HUB 10.3
3 x Midnite Solar Classic 150
1 x Midnite Solar 12 CB Combiner Box
1 x Midnite Solar 3 CB Combiner Box
5 x Midnite Solar MOV Surge Protectors (3 DC for combiners, 1 DC for GSLC and 1 AC for GSLC)
16 x L16RE-B Batteries (two 48V strings in parallel)
1 x DIY Sealed/Vented Battery Box (w/ two 48V Zephyr fans)
Racking (still figuring this out, but likely Ironside)
Cables/connectors (PV, batteries, inverter, etc)
I'm wiring the panels in 9 strings of 3 each. The reason for the three CCs is that I have three different roof facings: S (9 panels), SW (6 panels) and East (12 panels). So I wanted one CC per roof facing. I'll run two CCs (S and E) from the 12x combiner and the third CC (SW) from the 3x combiner. This also requires me to add another PV breaker in the GSLC and swap out the 2-pole GFDI with a 4-pole GFDI.
I was going to use FM80s at first, but I need AFCI and using the Classic 150s seemed to be the most cost effective way since Outback still does not have a great solution yet. They are coming out with the new Flexware ICS Plus, which has AFCI and rapid shutdown, but I hear it will be around $2K. California has not adopted 2014 NEC yet, so I don't need to have rapid shutdown, but I still need to comply with AFCI under 690.11 of the 2011 NEC.
Thoughts (good and bad are welcome)? Anyone using anything similar?
Thanks.
Thanks.
