Ok so i just bought 8 Renorgy RNG-320D 24v panels which i will be using for a schoolie build that will prolly be transferred over to a small home in the future. I was thinking of making this a 24 volt system.
These are the other parts i was thinking of getting though i have no idea what charge controller to use tho i was thinking of going with a victron controller. the table i have here is my solar panels specs. I am new to this though i do have a little electrical experience but so much to wrap my head around it need some additional help
-Victron MultiPlus 24/3000/70-50 120V VE.Bus inverter charger
-Victron Orion 24/12V-70A Converter for step down to any 12v items
-unknown charge controller was thinking also victron but don't know which one or optimal wiring for panels
-Crown CR430, 6V Flooded L16 Battery 430 amp hr (configured for 24 and for 2560w of panels)
Max Power at STC: 320W | Open Circuit Voltage: 40.1V |
Short Circuit Current: 10.08A | Opitmum Operating Voltage: 33.7V |
Optimum Operating Current: 9.50A | Operating Temperature: -40°F to 194°F (-40°Cto 90°C) |
Dimensions: 65.6*39.5*1.4 in (1666*1002*35 mm) | Weight: 40.8 lbs (18.5kg) |
Solar Cells: 60 Monocrystalline | Cables:12 AWG (2.95 ft) |
Junction Box: IP67 | Connectors: solar connector |
Module Efficiency: 19.18% | Maximum System Voltage: 1000VDC UL |
Maximum Series Fuse Rating: 15A |
