I'm thinking through an off-grid system and could use some guidance on DC breakers.
I'm thinking of going with an 800W 24V kit: New 800 Watt 24 Volt Solar Premium Kit | Renogy Solar
Four 100Ah gel 12V batteries, wired in series/parallel for 24V.
My main question is I'm also looking at a panel which would simplfy the whole setup, including tying into the inverter, and it has a DIN rail to hold breakers for the DC side of the system and I'd rather go with breakers than the two fuses that come with the Renogy kit. One is an in-line fuse (rated current 20A, rated voltage 1000V) and the other is an ANL fuse set, rated 40A, voltage rating 72A. I'm looking for recommendations for specific examples of appropriate breakers. I'm not as familiar with DC components and wanted to double-check to make sure I'm looking at this correctly. Thanks in advance.
