I have an MPPT controller. I was told the amps showing on it's LCD are the amps coming from the panels, not the amps actually going into the batteries. They said the amps going into the batteries are actually much higher? Is this true? If so, how much higher?
Announcement
No announcement yet.
MPPT Controller Increasing Amps To Battery
panel amps are much less important then battery charge amps, which is what a single ammeter should display. What does the manual say about selecting what the display shows?
While an MPPT CC should provide higher amps out to the battery then amps in from the panels it will vary based on the SOC of the batteries.
But I agree with Mike. Is there a way to select what the MPPT CC is measuring? Amps in or amps out.
It is also good to have a clamp on DC amp meter to verify what is coming in and going out. Some of those MPPT meters may not be as accurate as a hand held meter.
Originally posted by Mike90250 View Postpanel amps are much less important then battery charge amps, which is what a single ammeter should display. What does the manual say about selecting what the display shows?Comment
Originally posted by SunEagle View PostWhile an MPPT CC should provide higher amps out to the battery then amps in from the panels it will vary based on the SOC of the batteries.
It is also good to have a clamp on DC amp meter to verify what is coming in and going out. Some of those MPPT meters may not be as accurate as a hand held meter.Comment
Originally posted by AL1952 View Post
No way to change what is showing. It just says "Charging Current".Comment
Charging Current is amps going to the batteries or load. Stuff coming from the PV would be solar currentPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
I’m curious about the number of panels, Panel voltage, panel amps, and battery volts. Like to see how many amps are disappearing.Comment
He said if a controller has a BOOST setting it can increase amps while lowering voltage. Mine has a boost setting. Does this sound right?
"BOOST" means absorption in this context; IMO that translation/marketing choice is confusing to new folks.
Originally posted by AL1952No way to change what is showing.
