I was talking to a local solar installer, and they brought up the Generac solution as an option above ($$$) SolarEdge's option because it makes adding batteries easier. Has anyone played or useed the Generac solution? My plan isn't to add batteries for several years, as net-metering in Indiana runs until 2032. Just curious what the groups opinion of the solution, which I believe is based on the Pika inverter.
Generac Clean Energy Solution
When you add batteries, you will need a different inverter than one that works w/o batteries. The generator just lets you use fuel to generate power, and you could charge batteries, but to get AC from batteries, you need a battery based inverter.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
https://www.generac.com/for-homeowne...ergy-ecosystemComment
Generac are the home generator people but that bought Pika and a few other companies to create their solar solution/ecosystem.
It is easy way to go solar now and add batteries later. It is also much more round trip efficient than an AC coupled system
Andy
The Pika system has been significantly updated since Generac bought them. It uses a DC Bus system that allows both string optomized panels and batteries to be connected.
Andy
When I first looked at the Pika system it was not cost effective compared to a Powerwall. Is the price more competitive now?
It is interesting that they are going with a DC coupled system. The round trip efficiency is much better. I have often wondered how they were going to evolve their generator products to tap into that niche. Is it possible for a generator to be DC coupled?9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
I have been impressed with the strategic acquisitions Generac has made.
What I was speculating about was if their integration plans were some form of DC generator or AC generator with an inverter output that could AC couple with a GT inverter using their Pika Batteries as a buffer. It seems clear they are looking at the installed base of GT inverters as a market opportunity.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
I understand the issue with an AC generator. I am not sure I understand the two outputs on the generator, especially the one for the grid. Perhaps that is the transfer switch that is integrated.
AndyComment
I look forward to hearing more about their integration as it unfolds, because as I have said there is a huge market of GT solar installations that either want backup when the grid is down or some way to hedge against continued erosion of rates. Batteries and generators each offer solutions, with their own limitations but together there are synergies.
Years ago I purchased a Neurio and am pleased that Generac continues to support it after they purchase that company.. The Neurio was the data collection device inside the Tesla Powerwall Gateway 1 and I suspected Generacs purchase was strategic in terms of the need for data collections for an intefgrated product offfering to capture some of the market for leveraging GT solar installations.Last edited by Ampster; 07-19-2020, 11:03 AM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Tomorrow I find out the Solar Edge and Generac pricing. Originally, for batteries I was going to use the Tesla gateway, but I have 400amp service with 2x 200 amp disconnects so that is messy and carries its own price premium. Regarding Generac, since it doesn't do module level optimizers, how does it handle partial shading on the array?Comment
I am interested in the Generac/Pika configuration also. When Generac purchased Pika those batteries were way overpriced compared to the capacity of a Tesla Powerwall. According to @PVAndy they are more competive now. Certainly Tesla doesn't offer a generator backed solution and that seems to be the niche that the Generac/Pika solution can address. Presumably the Pika battery/inverter can be AC coupled to the Solaredge system.Last edited by Ampster; 07-20-2020, 03:33 PM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
I think the OP was confusing the Solaredge solar panel configuration with the Pika battery system. As you know you can't run a Solaredge inverter without Optimizers.
Andy
Thanks for the clarification on the optimizers. In order to comply with Rapid Shutdown requirements everybody selling inverters for installation in the USA ultimately has to find a RSD solution as it rolls out through the various regional building departments.Last edited by Ampster; 07-21-2020, 10:44 AM.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
