Discharge rate vs battery life
  • fw12
    • Nov 2017
    • 37
    Battery chemistry: LiFePO4
    Battery 1:
    12V 200aH
    Max discharge rate: 200A
    Battery 2:
    12V 200aH
    Max discharge rate: 40A
    Both battery banks are identical, except that bank 1 is high drain.
    Question:
    Let's say I decide to drain both banks at a rate of 20A. Does it mean that bank 1 would last longer than bank 2?
    And by "last longer", I mean the number of years before the batteries die.
  • NEOH
    • Nov 2010
    • 478
    Insufficient information....
    Please provide URL links to mfr website & datasheets.
    • fw12
      • Nov 2017
      • 37
      Thanks for your response.
      This is not specific to any product.
      I'm just trying to understand the principle.
      But if you insist on a particular product, pick one to illustrate with.
        • 15123
        Battery 1:
        12V 200aH
        Battery 2:
        12V 200aH
        Question:
        Theoretically battery 1 should last longer at that drain rate but to really understand the lifespan of a battery would be to read all of the technical data provided by the battery manufacturer.
        Unfortunately even with the spec sheet your battery may still act differently then expected due to a number of variables.
        • fw12
          • Nov 2017
          • 37
          Thank you.
          All other variables being the same, I believe battery 1 should last longer due to more robust components.
          Ultimately, only a test could prove it.
            • 15123
            Thank you.
            I agree with you. The final decision for me would be the cost over the lifetime of a battery. That is a choice you have to make.
            • NEOH
              • Nov 2010
              • 478
              Thank you.
              If all else stays the same ( like overall size ) then ...
              What if the larger metal components ( that support the huge amps ) leave less space inside for active material?
              Less active material = fewer cycles = shorter life.
                • 3649
                What little I know of the subject has been drawn from the Teslamotors forum. Fundamentally the difference in the high drain (power density) cells used in the cars and those used in Powerwalls (energy density) is almost entirely in the electrolyte. Consider that anecdotal but we do know the form factor remained the same until recently. As far as shorter life i think the guaranty is very similar so somehow they may have struck a balance.
