Hi all,
I'm looking for some help and suggestions on adding some additional panels to my existing array. I currently have 6 Photowatt PW-1650 panels which are 165w each, these are the exact specs for them:
As far as I can tell, the panels now are wired 2 series / 3 parallel
These panels are a few years old, and I can't locate the exact same ones, and replacing them all is just not in the budget right now. What I would like to do is add some more panels (1-3 more) to get a bit more power from the sun. I can't add too many due to cost/space limitations. Can you guys offer some suggestions as to wattage/size/ that I should be looking for? The guy I spoke to at local solar shop said I need to use 300w or 340w panels (which are massive). Is that my only option? Could I go with 2 240watt panels?
Second question is, what would be the best way to wire the new panels into the existing set up? The new panels would ideally be located in a different spot than my current panels, do I need to run the wires back to the combiner box or can I join them at the solar panel breaker box closer to my charge controller?
I've attached a simplified diagram to help explain what I'm thinking... any suggestions here would be much appreciated.
Thanks,
Slav
24v Configuration | |||
Typical power [W] | 155 | 165 | 175 |
Minimum power [W] | 150 | 160 | 170 |
Voltage at typical power [V] | 34 | 34.4 | 35 |
Current at typical power [A] | 4.6 | 4.8 | 5 |
Short circuit current [A] | 4.8 | 5.1 | 5.3 |
Open circuit voltage [V] | 43 | 43.2 | 43.4 |
Max system voltage | 770V DC |
Thanks,
Slav
