Hi folks. I am currently using a 40A 12v/24v mppt charge controller (100V max, 500W/1000W max) to charge four 6V 225ah batteries tied series/parallell for 12V at 450ah. I have four 240W panels, but am currently only using two because it is a 12V system. The future plan is to run the batteries in series 24V when I can afford to get a good 24V inverter, and then connect the other two panels, but for now I'm stuck with the 12V inverter I have.
In the mean time, I'm looking for a battery charger to connect to my 120V/20A gas generator. There's a good chance that when I purchase the new inverter, it will include a charger, but that's still unclear at this point, and so I'd like to have the 24V option in the charger. So I need a 12V/24V charger. I'd like to be able to charge the battery bank, if half depleted, in the range of 8-12hrs, so I guess that would mean approximately a 20A charger?
I'd appreciate it if someone could tell me if I'm way off track here. If not, could you guide me to some charger options? Unfortunately, I'm on a really tight budget these days (otherwise I'd already have a new inverter), so taking that into account would be appreciated. Nothing fancy, bare-bones is what I'm looking for, as long as it treats the batteries well.
One other question: If the generator is running a charger, how does the panel charge controller respond to this?
Much thanks.
Edit: One other, other question: I guess there's an option to run a second charge controller to the 12V bank so I can hook up the other panels, rather than get a new inverter and run 24V. Does that seem wise, or no?
Much thanks.
