I just installed a PV system at my home in PR. The inverters and controllers are Schneider Electric. The inverter is a 6880 model. Could this unit connect to the internet? and if so, is there an App available that can access the information from this inverter. Thanks
Inverter App Connection
Generally, you use the schenider Combox $$ to interface between the Xanbus gear and the internet.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
As noted before, I own a XW6848 SE Inverter along with its System Control Panel. Can I obtain my daily PV production from this system? If so, can you provide me with guidance. ThanksComment
As noted before, I own a XW6848 SE Inverter along with its System Control Panel. Is it relatively easy to connect the Schneider Combox to this system and access its data through the related App. ThanksComment
