I have 3 panels (2 100watt & 1 150 watts) total of 350 watts, my current inverter is a 800 watt continuous. Do I upgrade my inverter and to what is I want to run say a fan or charge my laolap?
What inverter do I need?
To design ANY system first determine your loads; size your battery appropriately. Then choose solar that will 1) generate the energy you need to power your loads and 2) keep your batteries happy (i.e between about C/8 and C/12.) If you are starting with some panels you are doing it backwards. -
I appreciate your quick response, the system I have I purchased used just to have an electrical to start with living off grid. This consist of two 6 volt batteries, the 350 watts (3 panels) , charge controller and inverter. By load would that be the total watts as posted on the appliance? Such as Laptop. Input 1.5 amps output 3.16 ampsComment
No watt hours use din a day. You will quickly learn going off grid is really stupid. By doing so you just volunteered to pay 5 to 10 times more for electricity and become a very heavy polluter.MSEE, PEComment
Most Laptops run from 19v DC, If you run a 24v battery bank and use a 19v stepdown converter, you will have a much better time with your solar toys.Comment
120 VAC
12 volt DC with a Cigarette Lighter plug or Alligator Clips
Not many 24 down converters or step down transformer flavor options available.
MSEE, PEComment
Well while that is factually accurate, not many options available to make that happen. Power Bricks for Laptops come primarily in two Flavors:
120 VAC
Not many 24 down converters or step down transformer flavor options available.Comment
I have used this one on several set up's. It is made in China and comes in several voltage and amp options. It can also be used with big screen 19v TV's. there are other adjustable designs but I prefer this one as it is sealed.Attached FilesComment
