Is there an inverter with a battery input of 24 or 48v, an output of 240v, that doesn't cost an arm and a leg?
240v inverter that is economical
They all start with a kidney !
The issue is, Mass Production. The more they make, the cheaper they are. 240V needs are much less often than 120V, so there is a big price spike there.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
My off-grid home has two 120-volt inverters on two busses to make 240-volts. Apparently the original owner did use a 240-volt clothes dryer, I do not use this.Comment
Define Arm and Leg? And is it to supplement a grid tied system or stand alone285Wx9 / MNClassic 150 / CSW4024 / TrojanL16H-ACx4Comment
