I am in the process of having a second system installed on a vacation home in Costa Rica. OK this is the wild wild do whatever, but I need to ask this.
I was quoted a 20 panel (Canadian Solar) system and ABB String inverter.
The 20 panels rated at 325 Watt each so the system is being called a 6.5 kWh system
When I questioned the inverter the rating of it is 5.0 kWh.
I called them out and said it was only a 5 kWh system since that is all the inverter will produce.
Have any of you had this kind of rating. Which is correct? Am I wrong.
Thanks Randy
Thanks Randy
