What do u guys think about using a SolarEdge wave inverter instead of spending up to $1,500-$2,000 in upgrading the panel?
Announcement
No announcement yet.
SolarEdge wave inverter !
Originally posted by swpr77 View PostWhat do u guys think about using a SolarEdge wave inverter instead of spending up to $1,500-$2,000 in upgrading the panel?CS6P-260P/SE3000 - http://tiny.cc/ed5ozx -
Originally posted by swpr77 View PostBecause the inverter takes a smaller breaker from what I understand. No?CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I was trying to say if that inverter uses a smaller breaker then does it make sense to use that in order to skip upgrading the panel?
I want to make sure itComment
What is wrong with this site? It only posts whatever gets typed before the auto save. How annoying.Comment
I want to make sure using this inverter to prevent a panel upgrade is the right information that was given to me before I spend money on something that wonComment
Originally posted by swpr77 View PostI want to make sure using this inverter to prevent a panel upgrade is the right information that was given to me before I spend money on something that wonOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
forum anti spam protection. non-standard chars trigger truncation. not much issue with windows pc's but phones with non-usa based os are likely to be using non-std chrsPowerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
