So I just scored a terrific deal on a set of twelve 3 year old - very gently used 225W solar panels - they are German made QCells 225 polycrystalline panels - model # QC-C05-225, I have tested each panel and they are all working perfectly putting out open circuit voltage of 33.1 Volts / 6.7 amps each. I only paid $60 per panel so I think I did OK. or at least I hope I did .... now to match it to my old system ....
I need a new MPPT charge controller and I am lost as to what to buy .... in series all 12 panels are putting out 2.7kw and 400 volts / 7 amps .... so if I go that route I am going to need a 600 volt charge controller .. and yikes they are expensive ....
If I wire the panels in parallel ... am I right in thinking I'll keep my voltage to 34 volts and my amps to 84 ... so can I go with a much lower voltage charge controller .... and cheaper.... just as long as it can handle the amperage ????
I am still trying to get my head round the differences between wiring panels in series Vs Parallel ... pros and cons etc ...
My cabin's roof gets a min of 8 hrs of full sun without shade everyday (minus the clouds etc) and there is space to mount all 12 panels.
My electronics are Trace 3624 Inverter and batteries are all 24V .... 4 x Trojan L-16RE-B / 370 amp hour high capacity lead acid 6 volt batteries.
The whole set up is for a back up power supply to my grid connected cabin ... in the event of power outage I want to be able to run my small fridge, a few interior lights , charge a cell phone or 2 and maybe watch a movie on an old tube TV .... that kind of thing. Everything worked great back in Y2k on my old 960W panels and 16x T105 Batteries ....but those panels and old batteries are now dead and gone. The electronics are the same.
I don't have to use all 12 panels ... but I did have to buy them all to get that price .. but I figure more wattage from the roof is better . I just need some advice on which MPPT charge controller I should consider that can handle the new higher voltage and amps.
And yes I know my inverter electronics are old (1999) .... but they only saw two years of active duty .. and since re-comisioning them for service everything is working perfectly..... green lights across the board.
Thanx in advance for any / all insightful comments / advice.
