I've got my T6061 ground-rack frame pretty much complete... I'm almost ready to pour the concrete for my ballast blocks and then install the rails.
I will be using IronRidge XR1000 rails E-W, spliced together for a total of 33' in a 2Px10 configuration. My 5" T-posts are 8'-9" OC and the front of the 3" Angle front supports are 5' from the post. The 30-degree, 3"x1/4"x10' angled table extends about 3'-11" upward from the T-post. The Ballast blocks are 24"x96"x18" with the main post set another 18" in conc. I'm in a ASCE 7-05 90mph wind zone with 0 snow. Prevailing winds are from the SSW but storms come in from the East and North.
I have 5' lengths of 2"x1/4" angle I originally thought of using as a brace between the front and main posts but now I have an alternate idea, as I am considering whether the top cantilever would bend in a high wind vs supporting the frame from distorting.
I suppose both would be a safe option but adding another brace may be somewhat down the road.
My question is...
As is, would it be better to brace the upper table to the main post OR brace the front and main posts as shown in these examples ?
OR
In the case of supporting the top cantilever, is there a formula to calculate the optimum angle? I have 5' of brace but can cut it if necessary.
Thanks for your help
(ignore the rusty steel bolts...SS hardware is on order- the local bigbox is 4x the cost)
sd
My question is...
OR
sd
