I am installing 9 250 watt panels at 24 volts each to a solar Combiner box with three circuit Breakers mounted in it. I believe I need to connect three sets of three to the combiner box but am not sure if I should connect each group in parallel or series. I will be connecting the output from the combiner box to a 60 amp Commander controller which is connected to a 48 volt battery bank. Any advice on the interconnections for the set of three panels would be appreciated!
How to connect 9 panels to a Solar combiner box
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNH -
