The system I am working on has a battery charging "controller/charger" which regulates the charging of the batteries using as algorithm to control bulk, absorption and float charge rates. This to get the best out of the solar panel array. When the generator is used to charge the batteries it feeds back through the inverter and not through the controller. If you try to charge (top-up) the batteries when the battery voltage is fairly high the inverter will not allow the generator (alternator) to latch in. The fault reported is a "frequency" to high fault. Sometimes it will report "frequency too low" as well. If you put a load onto the inverter system or if the battery voltage is relatively low, the inverter allows the generator to lock in and it charges for about 20/25 minutes or so. Not nearly long enough to make a difference to the 200 AH batteries. It then starts kicking out again on frequency fault. Here are my questions :-
Could I put a separate load onto the generator to stabilize the frequency ? Will this eneable the inverter to lock in and stay in ?
Could I install a AC/DC rectiformer to produce the 100 volt DC (suitable current rating) input and feed this back into the controller in place of the solar panel power (change over switch) into the battery controller/charger ? Would the controller look after the charging in the normal way ? Would I need to switch this off when the batteries are full or will the controller regulate the power as it requires it ?
Looking forward to hearing some thoughts !!!
Regards,
Derek Laing
Regards,
Derek Laing
