Hello I posted a topic few days ago on my small load solar build for camp. This is what I'm thinking so far from info I have gotten from SUNKING and others and just need to figure out few more things like what size breakers to get from battery to inverter and do I need fuses between the panels and controller?
4- 100w panels in series at 17.1v/5.8a a piece will equal 85.5v Isc and 5.8a output?
So with the 4 panels in series a Tracer 2210a MPPT charge controller that has 100v/20a max inputs will work I presume and will run at 24v?
4- BATTERIES 6V 235AH 478RC/25A DEEP CYCLE (BIG 6) in series to make 24volt system
SAMLEX PST-600-24 Pure Sine 24volt inverter
35 feet of 12awg wire between Arrays and Controller?
2 feet of (what size I need) wire between mppt controller and batteries?
1/0 cable to hook up batteries in series?
1/0 cable from batteries to inverter?
What size cable from Inverter to AC panel 15 feet away??
If batteries get low due to lack of sun or night time is it best to charge the batteries via a marine charger with the 2000w genny and still use the battery bank to run the camp while charging or run the camp with the genny and have the inverter turned off and wait for the sun to charge the battery bank?
Here is original post with my specs for camp
Small load AC camp in Northern Ontario setup and suggestion
Want to start of by saying hi to everyone as I'm a greenhorn and this is my first post.
From what I've been reading and studying he's last 2 weeks solar can get complicated with all different parameters to consider. Every hour I read I learn something new that actual contridicts my previous thinking. My father in law and me are installing solar at our Northern Ontario camp that currently is being powered my AC and a 2000 watt Honda suitcase genny. All of our appliances (hot water, stove, fridge, freezer) all run off Propane so no big loads.
Here is what we would run off solar and all specs of what we would need and use it for
Led lighting 3w
Satellite 30w
Lcd TV 110w
DVD player 35w
Small Table fan 15w
At one time we will not be more then 180w with usage around 700-900w for the day. In the no snow months we usually get up to camp around noon-2pm on a fri and stay till noon on a Sunday so rely only using power the Friday night and Saturday cause Sunday is wake up and pack to come home. Maybe twice a summer we might stay 4-5 days but can suppliment power if needed with the 2000w Genny
Led lighting 3w
Satellite 30w
Lcd TV 110w
DVD player 35w
Small Table fan 15w
