Hi Everybody,
I'm dealing with the following situation:
3000 Wp Hybrid System
Available roofspace
Facing East 6 panels 250 Wp tilt 22 degrees
Facing West 6 panels 250 Wp tilt 22 degrees
Inverter has just one MPPT
Anybody experience with PolyString?
So what I want to do is make two strings for each roof of 6 panels each in series. These two strings will be connected (Parallel) to the one MPPT of the inverter.
The info of the panels is:
12 x Canadian Solar 260 Wp
Voc 37,5 V
Vmp 30,4 V
Imp 8,56 A
Isc 9,12 A
Inverter Growatt 3000HY
maximum PV Input Power 4500 Watt
Maximum input current 18A
MPP Voltage Range 250 - 450 VDC
Startup Voltage 115 VDC
So what do you think?
Thanks for advice and tips
Regards
Johan
Available roofspace
Voc 37,5 V
Vmp 30,4 V
Imp 8,56 A
Isc 9,12 A
Regards
Johan
