Announcement
No announcement yet.
Sunny Portal, Speedwire WebConnect board, and Sunny Boy 6000-US
  • Filter
  • Sunny Portal, Speedwire WebConnect board, and Sunny Boy 6000-US
    I just purchased the Sunny Boy 6000-US for replacing a failed inverter in a 10 year old system. I am looking at buying the Speedwire WebConnect communication board so I can monitor the performance of the system via Sunny Portal. I had hoped there was a wifi solution out there, but it looks like the Speedwire is the only viable way to connect.
    Are there any surprises I will face if I purchase the Speedwire? I know the router needs to be configured to handle DHCP, but are there any other configuration settings needed on the router (port forwarding, or similar) - or, does the Speedwire and the Sunny Portal deal with establishing the connection?
    Do I have to be concerned with the Sunny Boy firmware version 1.12 with this card? Documentation indicates it should work - checking to see if this matches people's experiences.
    It looks like there are no costs to using Sunny Portal - is this accurate?
    Finally looking for a good source for the board - AltEStore has it priced at $175.88 - are they a reputable reseller?
    Thanks in advance
  • #2
    Best pricing seems to be at Renvu. I know someone from AltEStore used to post on here frequently (Amy?) and I think they're quite legit.
    (Full disclosure - I have been implicated to be a Secret Agent for Renvu - this is simply not true. Meet me in the parking garage at 3rd and Main at midnight and I'll explain everything... come alone - sorry, inside joke but had to say it as yet again, it looks like I'm promoting them...)
    • #3
      Appreciate your pointing me to Renvu - I won't turn you in... :~}
      Now, just need to make sure there aren't any surprises in store if I use the comm board. I've been down the road before, where I needed to configure the router in a way it broke communications for other devices. It looks fairly straight forward, but that doesn't guarantee there aren't gotchas.
      Thanks again
      • #4
        What made you decide to go with the 6000 series over the newer 6.0 with built-in comms and other upgrades over the older x000 units?
        • #5
          The wiring on the solar panels won't meet code requirements when used with the xformerless inverters, so rather than addressing that issue, I chose to stay with an inverter that had the isolation (xformer).
          • #6
            Too legit, too legit to quit.....
            Hi, things got busy for me, so I had to back away from the forum for a bit. I'm still around (and now singing some MC Hammer).
            Solar Queen
            altE Store
            • #7
              Welcome back Amy. We missed you.
