Hi all need some advice
Long time lurker and learned a lot of this great forum
Want expand my PV system and want to hear your opinions and comments
Have a pretty thick skin so go ahead if needed
I have a PV installation with 24 X 250 W mono panels orientated south no shade on a ground mount
They feed at the moment a Chinese inverter as grid tie with zero feed in grid what is working alright
Looking for expansion and want to change the inverter for a solar edge who would be also doing the zero feed in grid with the energy meter SE-MTR240-2-200-S1
The expansion would be another 6 Kw or more looking at the Aleo 305 W 24 pcs or the Solar world 270W 24 pcs
Understand that I have to mount the optimizers on the panels for the 250W I can mount the P 300 correct?
Is this also possible for the 270W panels and will this reduce the panels to 250W or do I have to use the P400, for the 305W I have to use the P400 for sure correct?
Then the choice of the inverter would be the 10Kw or the 11.4Kw difference in price is minimum
Thanks in advance for all the comments advise
