Hello all from San Antonio TX.
I will be installing a 1.2kw system consisting of 4 300 mono panels. These panels are 72 cell 24 volt. Two of these panels will be connected to a 1200 watt power jack grid tie inverter and then be plugged into a standard outlet. The other two will be the same. I'm wondering how I should connect the panels (series or parallel) in each pair. The inverter specs say 28 to 48 volt. and I know the VOC is shown on the panel as 45 volts. Any thoughts please
Thanks
Kelly in San Antonio
Thanks
