I'm getting ready to mount 2 panels (I took sunkings advice and used 2 instead of 1 panel), thus needing to know parts and pieces of what to purchase for a DIY project. I'm guessing something at my local lowes will have something, or would it be cheaper to purchase a premade one?
DIY Top Pole Mount for only 2 panels
If your good at metal fabrication, You should be good to go. Most important thing is to make sure you span the entire width of the two panels. Solar panels are not meant to be side mounted and would be damage by such mount. The taller your pole the larger diameter it should be. Two solar panels will act as a sail, even in small winds.
