I have some questions regarding solar setup and I hope you could help me a bit.
I have a solar charger with the following info:
Rated Voltage: 12V / 24V ( Auto Switch )
Rated Current : 30A
Max Input Solar Panel Power: 720W , Connect 24V Battery ( Connect 12V Battery, Max solar Panel Power: 360W )
I have 100 watt 6 amp panels, and a 12 volt battery bank.
Am I only able to put 3 of these panels on that charge controller? That means I need a controller for every 3 panels? Can they all feed into the same battery bank?
I've also received conflicting info on the size of wire to run from the panels to the charge controller...the panels are 65-75 feet away from the charge controller....and from the charge controller to the batteries, a distance of 3 or 4 feet.
One final question, I've been told to hook the controller up both of the following ways to the batteries...positive to the first battery, negative to the last battery in the bank...and then another source says both to the first battery.
As you can see, I am a novice at this, and although I am going offgrid, it wasn't by design, it's because of necessity, I was supposed to be able to get power there.
Right now I am powering my lights (12 volt mushrooms) with the batteries, and recharging with the generator until I have everything sorted.
Thanks for any help you can give.
Rated Current : 30A
