Aside from pricing, is there a benefit to using Enphase S280 inverter vs. Solaredge and DC optimizers? 32 panel ground mount system. Thanks, Craig
LG Neon 72 Cell (LG360N2W-B3) with Enphase S280 or Solaredge P400 and DC Optimizers?
the P400 is the SolarEdge optimizer. SolarEdge inverters do not work without the optimizers.
It is really your only choice since enphase does NOT support any 72 cell modules so you can't use the LG360N2W-B3 with any enphase optimizer including the S280.
OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNH -
If it is a ground mount system with no shading or uniform shading you may want to consider a string inverter.Comment
Thanks. Although the specs reference 60 cell compatibility, Enphase wants the Solar Panel input DC voltage to be within operating voltage of Enphase which in LG 360W case, it is within the range.
They are referring to the bigger 72 cell modules. Assuming this configuration works, any additional thoughts vs the Solaredge? Are Enphase or Solaredge string converters? If not who makes them? Why the consideration? More efficient?Comment
