I saw a thread “Thoughts on My First Solar Design”, so I may have reached the right place.
On each website, video tutorial, you always find the same process. Step 1 calculate your loads, then start the maths...
In fact nobody seems to consider that you may be using power and get some from the sun at the same time...
I’m considering the problem from a different viewpoint.
How much am I willing to invest in my battery bank?
What do I need in order to charge it?
How do I manage my power consumption in order to fit into the frame I’ve designed?
Like: ‘do not open the fridge after dusk...’
How can I preserve my batteries?
I have a twofold problem: no grid, no water. To give a first answer to my last question; I won’t have a pump connected to my inverter, but I’d rather use a solar inverter to drive my pump which anyway is not going to work all the time. Such an inverter also avoids surge when the pump starts.
POWER SUPPLY:
First the battery bank: 16pcs 6-volt 245Ah deep cycle batteries in series, or 23,520 Wh, 96Vdc.
25% DOD: 5,880 Wh available solar irradiance: 4.91 h/d 5,880÷4.91=1,190W. The whole system is not 100% efficient, let’s take a correction factor of .66: 1,190÷.66=~1,800W
When the sun rises at noon, it’s hot. Let’s take 65°C. (40°C air t° + 25°C from the soil)
Let’s take one example, the final choice will be made later.
Pmax Temperature Coefficient: -0.47%/°C it’s a 250W-60 panel, at 65°C : 203W
1,800W÷203W/panel=~8.8 panels, let’s say 10pcs.
Voc = 37.1Vdc, Voc is to be observed when there’s no current, so at dawn, when the panels wake up.
The lowest t° is around 10°C, let’s take 5°C.
Voc Temperature Coefficient: -0.32%/°, at 5°C : 39.5 Vdc.
What I have in mind is a PV array that can meet both the needs of my power supply and my water supply. I could see that solar pump inverters require a quite high voltage, so I’m considering two configurations.
Power: two strings of five panels in series, Voc= 5x39.5Vdc=197.5 Vdc.
Current: 250W nominal, Power tolerance 0, +5; 262.5W. 262.5W x 10= 2,625W.
Battery bank: 16 x 7.2V (bulk) = 115.2Vdc; 2,625W÷115.2V=22.8A, let’s consider a 30A MPPT controller charger, 96VDC, 300VDC PV input Max, 3400W PV input Max.
Inverter: 245Ah C8, 245÷8=30A 30X 220VAC=6600W; a 6kW inverter charger. (96Vdc-220VAC, 50Hz)
WATER SUPPLY:
Second configuration: one string, ten panels in series. Voc 395Vdc.
Inverter MPPT input range: 100-440Vdc.
Inverter Voc Max: 450Vdc.
PV array reconfiguration: combiner box with two four-pole DC isolator switches.
Beside this there will be a diesel genset (5kW) as back up in case of peak demand or weather overcast, batteries: one day back up only.
I’m a green pea in the solar world, so I would very much appreciate your comments on this project and this approach. Location: Loei, Thailand 17°Lat. N.
POWER SUPPLY:
WATER SUPPLY:
