I have a thought that when it came down to a pinch and I might need emergency power, I could use my solar panels for to power essential items.
Does this seem possible without any other items?
My current system located in Tallahassee, FL is:
5.5kW grid tied solar power system consisting of 24x 230w Trina TSM-PA05 with max power of 30V at 7.66A
Xantrex GT 5.0: DC power from array when online reads 240V and up to 21A
Essential items to be run:
13W CFL light
22cu ft Refrigerator with Freezer 537 kW/yr
Laptop or other small electronic/charging of cell phone 100W
Can I repurpose existing items for an emergency? I.e. powered from car battery while charging them? I understand this will potentially wear down the battery, but we are speaking of emergencies.
I have two car batteries and also a hybrid 2006 Toyota Prius, any way to use this?
What size inverter should I purchase to power the refrigerator? It would seem that one rated for 1000 watts peak surge would be sufficient with 500 watts continuous. Is it possible to repurpose a backup UPS connected to the car battery for this function?
Is a charge controller required?
I can access the bare solar cell +/- wires from the Xantrex. What are the potentials for damaging my system by connecting wires to the system if I follow the following steps (and are all of these steps necessary) after a power failure occurs:
1. Flip dual circuit breakers to off position
2. Flip AC/DC switch to disconnect position
3. Wear rubberized boots and gloves
4. Connect alligator clips from battery terminals to the respective String 1 PV positive and negative terminals.
After 1 hour of charging, disconnect.
13W CFL light
