OK so I got all my paper work turned in to empire electric On Wednesday. they have called everyday with questions, so at least they are looking at the application. But sadly it almost seems like they don't want to approve my grid inter tie.
Anyway the latest round of questions was how is the transfer switch wired up. Luckily I was able to email pictures to my original electrician that wired the house 3 years ago and the electric engineer guys at Empire. I think they will get it worked out today.
If the application is approved, I'll be buying 10 Yingli 230 watt panels, 10 Enphase M190's, and the Enphase EMU for monitoring. The total system cost shipped to me with taxes and all is $6995.
I am very excited about finally starting. I have wanted solar for years, probably since I was a little boy. So I am kind of a geek.
Anyway, I intend to mount these off the south end of my barn as kind of a lean to set up. But eventually I would like to mount the panels on pole top mounts in the yard, with the ability to pivot so as to track the sun through out the day. I read about a DIY system where a guy used refrigerant and a double acting hydrolic cylinder to actuate the panels. The energy source was the solar effect on the containers the refrigerant is stored in, using shades to balance the heat until the panel directly faces the sun. I understand the principle behind this set up but I haven't seen a detailed build up of it. The original one was in Mother Earth News in the 70's. If anyone has more info about this set up I would appreciate any hints or advice. Also if there are any specs on building pole top mounts as a DIY project I would appreciate info on that too. I have done some digging, but no one seems to do it this way. Maybe that is a sign it is a stupid idea. I have no idea, but it seems it would add some much needed efficiency to my system with out adding costly solar equipment.
I intend to keep this thread running and posting updates. I'll photo document as well. I kind of look at this as a journal for my project. And a way to get my problems and questions solved. Thanks for your readership, and thanks in advance for your help.
