Need a breaker or not?
  • GeorgeF
    • Nov 2018
    • 277
    Suppose someone is planning to install one solar panel with the highest capacity and a (mppt) chargecontroller to charge one 12v deep cycle battery.
    Does he need any breaker if there is a built-in mainswitch of turning off the chargecontroller?
    The charge controller has to be DISCONNECTED from the PV before disconnecting from the battery. So that's 2 switches you need.
    Running raw, uncontrolled power into a controller that is not connected to a battery, creates a fault state that may or may not be destructive. Experiment with your expensive gear and be sure to record the raw PV voltage, and let us know what happened.
      • 15125
      Remember breakers and fuses are there to protect the wire and not necessarily the equipment.
      Also as Mike stated having a way to safely disconnect a component is both smart and will pay for itself.
