Hi everyone !!!
I want to start with a short disclaimer: I have 0% former knowledge at electricity and all of this system was designed thanks to this forum, youtube videos and blogs (my questions might sound a bit ridiculous to some of you but please be gentle with me)
I am travelling abroad and purchased a small station car in order to travel more freely, right now I am very close to finish makeover of it into a small "home"
the system is very small, it is only for the need of charging my computer, drone, camera batteries and 1 lamp.
My Equipment so far
PV: 100W, 18.1V 5.52A
CC: 10A
Battery: 12V 65AH
Inverter: 400W
*Set of cables which I got with the solar panel - "TOP CABLE TOPSOLAR" 2mm/12AWG/3.30 mm2
*Distance from PV to CC - 5m/16.40ft
*Distance from CC/INVERTER to BATTERY - 30cm/1ft
Questions:
1. cable diameter/AWG:
-Between the PV to CC this cable seems suitable (with 2% Voltage drop)
-Can I use the same cable between the CC to the battery although calculations shows that 17AWG is needed ? (will I have major lost of power?)
2.Breaker between PV to CC:
-Where the breaker should be located? close to the PV or CC?
-Should I install a breaker only on the + cable or on the - as well?
-Can the breaker serve as safety switch as well for turning the system off/on? (if not and you recommend adding an extra circuit breaker please tell me where to place it)
3.Breaker/Fuse between CC to Battery:
- is there a special recommendation to use a fuse or I can use a breaker for this part?
4.Is there a big difference and yield lost by connecting a simple 110V light socket to one of the inverter plugs or should I definitely wire it with a fuse to the CC ?
hope I can find some answers here because I don't know any one with knowledge in that field, thank you a lot for reading !
My Equipment so far
CC: 10A
Battery: 12V 65AH
Inverter: 400W
Questions:
