I am wanting to build a stand alone solar system
I have 8 X 200 watt vm 36.4 Im 5.5 a and setting up a 24 volt battery bank with a 225 ah and later on proberly another one the same size
many idea how I should wire up the panels (how many in series ) how many in parrarel
cable size ? not far away less than 5 Mtrs panels to battery bank
the inverter I will be using is ESG - 3000
2400 watt 24 vdc 140 vac - 275 vac
240 volt Ac 50 hz MPPT 20 a
max panel power 30 - 66 dc
any help apprieciated thanks
