I think the manual is referring to the "Shading and Snow" entry screen. To engage the self-shading model (for conventional panels), the entry needs to be changed from "none" to "Standard (non-linear)".
Now is probably a good time to mention that your goat seems to have eaten whatever image you had put into post 38. For what its worth, when I post images, I usually use the windows snipping tool to take a screenshot and upload the file it creates.
For different roof surfaces, you can manipulate the albedo setting. The model will give a difference between those surfaces if it is set up to show it.
