Received the engineering plans today and I'm not sure I understand this correctly so if someone can clarify I'd appreciate it. We are getting a 11.5 kW (36 LG320 neon 2 gen 4) system installed. Original plans said we'd get SE15k-AUS inverter and P400 Solar edge power optimizers. Looking at the engineering plans today, I see we are getting SE10000A-US inverter and P320 power optimizers. Doing some research online, my understanding is that the inverter is undersized and capped at 10kW vs the 11.5kW we need for the system. Am I wrong? Thanks in advance
This is the response I received from the company: "Remember a 10kw inverter is AC current and that equals 11.7kw in DC which is totally fine for your system size"
Is this true? and if it is then why did they write the SE15k inverter and p400 power optimizers and then later change them to lower sizes? Thank you
