Last summer, I installed a 24 volt panel. To determine its location, I used some suggested methods to find where the panel would get be exposed to the sun for the greatest number of hours during the day. The panel is on a pole in the ground. The highest point of the panel is about six feet off the ground. I thought for sure this panel would get as much sun as possible. When the winter rolled around, however, the panel was covered by shade for a significant portion of the day. The methods I used to place the panel were suggested by people and literature that I thought were knowledgeable on the subject.
I am going to install a second panel and wire it with the existing panel. Does anyone have any suggestions on how I should determine the location of the second panel? Should I wire the second panel parallel to the first panel or in a series with the first panel. I currently have two six volt batteries wired in series and a PVM controller. I understand that I may need a different type of controller to get the most efficient use of the panel(s).
I have considered moving the first panel but am not sure its worth the effort.
The off grid system I have now is not producing enough electricity for my needs. I use the system mainly to power items in my detached garage.
Your help, comments, counsel and advice would be greatly appreciated.
John S.
John S.
