Where does one normally wire in the inverter power?
  • supertrucker
    • Jun 2016
    • 30
    I have a mobile home that has a meter and a switch similar to this:http://tinyurl.com/ztn8q2p
    Is that where I would wire in my inverter power or would I have to have an additional switch?
    • 3802
    Hard to say. There are several different ways to interconnect. Most mobile homes do not have the roof structure for roof mounted solar though.
    • supertrucker
      • Jun 2016
      • 30
      I guess what I'm wondering is can I wire directly to the unenergized side of this switch? I'm not exactly sure what you call this switch since it is actually a circuit breaker and not a true knife switch? My electric company says they give you a smart meter and program it to do net metering, but I didn't know what that wiring diagram looks like exactly? If I just got my system rewired with a plug in for a generator could I just tie into that? I want it to be DIY ready where I could run my own inverter wiring directly to the input.
        • 15124
        I am sorry I just don't understand.
        You want to perform a DIY wiring connection to your motor home but don't have a clue about electrical wiring and the safety codes.
        I would respectfully ask you to go find someone that has an electrical license to perform the work and stay away from the dangers of electrical power.
        Getting help on an open forum may end up getting you hurt. Please do not perform the work yourself.
        • supertrucker
          • Jun 2016
          • 30
          I would respectfully say that many people plug in portable generators and I believe it is the same standards.
            • 3802
            It is not!
              • 2331
              Very different animals. A generator is a power source that energizes an otherwise-dead distribution network. We have used such systems for as long as we have had electric power. A standard grid tie inverter adds power to an already-energized system and cannot be used to power it alone. Different goal, different safety issues and different risks.
              • supertrucker
                • Jun 2016
                • 30
                Back to my original question...I have a cutler hammer disconnect box between my meter and my circuit breaker panel that sits outside on a pole. I live in a mobile home. I'm wondering if I can wire the inverter directly to the load side of the disconnect box? I'm just trying to assess what additional hardware I would need to attach an inverter to the utility source. The utility says I can get a net metering meter if I like. I currently do not have one. I realize some people use a spare space in their circuit breaker panel to back feed power. I have no empty slots since it is a 100 amp panel.
                I found this device and wondered if this is typically allowed by the utility? http://connectder.com/wp-content/upl...R-cutsheet.pdf
                  • 15124
                  Short answer is NO. You can not wire your inverter between the meter and the circuit breaker on the pole. You will need some type of net metering agreement with your POCO.
                  Second the only way you could install that device you show at the meter would be to have the POCO do it for you. If you touch your meter (actually it belongs to the POCO) you could be fined.
                  Are we clear on this? If not then please stop asking for something that is both illegal and dangerous.
                    • 2331
                    You would need a new load center and a net metering agreement, along with the panels, inverter, mounting hardware etc. One alternative to a new load center is a line-side tap, which can be done with a meter adapter in some cases (as in the link you posted.) You CANNOT do this yourself, period, and no amount of "but what if I . . ." will get around that. Local solar installers who are familiar with your POCO's requirements would be the best place to start if you want to do this.
                    • supertrucker
                      • Jun 2016
                      • 30
                      I found this: http://www.cooperindustries.com/cont...ers/MPV-15.pdf Is this something the POCO will let an electrician install with a net metering agreement?
                        You have to ask the power co what they allow.
