Announcement
No announcement yet.
Installation of a 5MW plant at my university
  • Filter
  • Installation of a 5MW plant at my university
    Installation of a 5MW plant at my university (Jordan, Middle East)
    two-fold solar power plant:
    1) 1 MW DC low-voltage grid-connected photovoltaic systems at the main-spine, pedestrian walkways, car parking lots.
    2) 4 MW DC medium-voltage grid-connected photovoltaic system.
    More than 16,000 panel used, from Yingli Solar, YL310P-35b.
    Inverters from ABB. 27.6, 20 and 12.5.
  • #2
    Neat! What percent of the university's power will it supply, and what is the payback time?
    • #3
      What type of monitoring is planned for the installation ?
      • #4
        DanKegel
        100%.
        But the percentage may be reduced, because there are new buildings under construction at the university.
        • #5
          J.P.M. EVO from ABB
          and they will use SCADA too
          • #6
            I would be concerned, that some day, someone carrying a metal pipe, etc on that walkway
            would accidentally poke it through those panels overhead. The system might be operating
            at 1000V, so it could easily be fatal. We are not allowed to have power lines that low.
            Bruce Roe
            • #7
              Bruce Roe
              The station is still under construction, the wires appear in the image have been linked.
              I think that's shown you otherwise existing in fact, panels rising from the ground at least 4 meters.
              If this increase is not enough in terms of safety, it means that we can not design canopies covered with solar cells :l :l
              • #8
                I see many parking lots with similar setups - and those haven't been a problem that I've heard of.
                It's certainly possible someone could be maliciously trying to damage the panels with a metal pole and hurt themselves.
                I think it's as likely as an idiot pokes a pole into a overhead power drop from the utility (which is about the same height and hurt themselves that way too.)
                (probably less likely - I can see someone using a pool-cleaning pole with a brush/net/etc and not thinking of the OH line when they walk around the corner of the house with the pole in hand.
                • #9
                  The height of the panels over a parking area or walk way is regulated by the NEC along with how easy it would be for someone to get shocked by exposed wires or energized connections. I do not have the latest NEC in front of me but IMO 4 meters should be high enough to keep it out of reach of non certified people thus making it safe. It also comes down to the voltage rating of the system.
                  Of course you sometimes have to make it even safer because someone may be stupid enough to try to touch the wires with a steel pole.
