For sure this is an easy one, but I am not totaly sure how to connect these modules with the inverters (how many per inverter I can connect)
In bold there are the ones used in the calculations below:
INVERTER
MODULES
Using the maximum power point data:
Should I connect in series 16 modules in order to get 38.1 x 16=609,6V (with 9.06A)
And then connect those groups in parallel with a total of 2 to make 9.06A x 2=18,12A
And all that connected it to 1 inverter (having space for 2 more groups of connection)?
That way we would get 609,6V x 18,12A=11046W per one
11,046W x 3=33,138W in total per inverter (which is still under the Max. DC input of 33,800 W)
Is that right? Should I use other data for the module?
Thanks a lot!
INVERTER
Code:
[B]Max. DC input 33,800 W[/B] Max. input voltage 1000 V Max. input current per MPPT 23 A Max. short circuit current per MPPT 32 A Operating voltage range 200 V - 980 V MPP voltage range at full loading 480 V - 800 V [B]Rated input voltage 620 V[/B] Max. number of inputs 6 Number of MPP trackers 3
Code:
[B]STC ELECTRICAL CHARACTERISTICS[/B] Rated Maximum Power Pmax (W) 345 Open-Circuit Voltage Voc (V) 46.6 Short-Circuit Current Isc (A) 9.48 Module Efficiency (%) 17.7 [B]Maximum Power Point Voltage Vmpp (V) 38.1[/B] [B]Maximum Power Point Current Impp (A) 9.06 [/B]
Thanks a lot!
