ggbgfhhfghfgh
SMA 4000TL - daily generation total resetting just after lunch?
Are you getting any fault resets or error codes ? 1pm is close to the peak power/heat period of the day, and some sort of fault could be happening.
Or maybe the Grid voltage goes out of spec ? Neighbor turns on a big welder and spikes the power line ?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Yes, wrong time (or timezone) could definitely explain it.CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
