I have an off grid 320 watt panel system - 2x60 and 2x100 watt panels - working well with PWM on 8x6 volt golf cart batteries - 1600ah capacity. El Niño has been giving us a lot lot of cloudy days so I am exploring an MPPT controller to salvage the lower light days. My question is can I run the four panels in series or perhaps pair the 60s and the 100s and run them in parallel? The load is about 300 watt-hours of steady state computer electronics around the clock plus RC airplane batteries of 1000 to 10000 mah batteries that are charge in an hour. More at flypcc.org/ camera.
Announcement
No announcement yet.
Mix 60 and 100 watt panels in series. Advice needed
Renege 100 watts:
Maximum Power: 100W
Maximum System Voltage: 600V DC (UL)
Optimum Operating Voltage (Vmp): 18.9V
Optimum Operating Current (Imp): 5.29A
Open-Circuit Voltage (Voc): 22.5V
Short-Circuit Current (Isc): 5.75A
Output Cables: 4.0 mm2 (0.006 in2), 800mm (31.5 in)
Connectors: MC4 Connectors
25-year transferable power output warranty: 5-year/95% efficiency rate, 10-year/90% efficiency rate, 25-year/80% efficiency rate
5-year material and workmanship warranty
The 60 watt panels are from AIMS Power. They no longer sell it and don't have a spec for it on the website aimscorp.net.
They do have a spec for a 120 watt.
I understand that putting four panels in series won't work to full spec. But how about series parallel with 60+60 in series plus 100+100 in series and then parallel them. If my battery bank is sitting at 12.0 volts each side should kick in with 6+ volts on each panel. Can I feed that system into one MPPT controller or do I need two?Comment
Bump, still need answer to last reply
2 60 watt/22volt in series , two 100 watts/22volt in series, then parallel the two pairs. Will that give me the full 320 watts of power capability? I have a new Epever 40 amp MPPT controller.Last edited by Slacsteve; 10-04-2018, 08:33 AM.Comment
You could measure the open circuit voltage of the 60W panels, which will not vary a lot with sun. The maximum
power voltage will then be about 80% of that. The maximum power current (good sun) will be 60W divided by
the voltage. What is your battery arrangement? Bruce RoeComment
Battery bank is a mixture of 6 volt (pairs) and 12 volt deep cycle batteries in parallel totally 1400 ah but degraded to about 55%. Recharge seems to max out at 12.3 volts. I need to equalize them.Comment
Originally posted by Slacsteve View PostBattery bank is a mixture of 6 volt (pairs) and 12 volt deep cycle batteries in parallel totally 1400 ah but degraded to about 55%. Recharge seems to max out at 12.3 volts. I need to equalize them.
Your 320 watts and 40a CC will never get your batteries back up to even 80% SOC.
I would choose the best batteries you have and try to make a 200 to 260Ah battery system which will about right for 320 watts. Otherwise get more panel wattage and a bigger CC.Comment
Panels may be put in series with similar current ratings, parallel with similar voltage ratings. It
appears you might use an MPP charge controller for your pair of 100W panels in series, and
another MPP charge controller for your 60W panels in series. If both strings were of nearly
the same voltage, the 2 strings could be parallel to a single controller. Bruce RoeComment
That's what I wanted to hear. I will try 60-60 in parallel with 100-100. It should alllow me to charge earlier and later in the day with MPPT and the higher voltages at the ends of the day.
thank youComment
