pls what could lead to sudden amps drop on a pv array that use to be very effective during a bright sunny day but now only charge faster during the early morning hour and charge very slowly during peak hours?
drop in amperage
Could be a few things.
1. Which is doubtful is you are using less energy, thus your batteries are fully charged and can take no more charge. Will also mimic #2.
2. Most likely candidates are: Batteries are near end of life.
3. Shade from a single leaf or branch can shut your system down depending on how the panels are configured.
Does not sound like an equipment problem if you are charging in morning Sun other than batteries or shading.MSEE, PEComment
I was suspecting heat guyz as it was mounted on my roof with no space nw there is a little space inbetween the panel and the roof.
The result is amazin fenx guyzComment
how did "no space" on your roof transform to "now there is a little space". What happened ? Did panels shift?Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
