  • Filter
  • New Houston Bus RV Conversion
    Hi folks,
    I live in the Houston area, and have started my own school bus RV conversion. I had been planning on buying a camper/travel trailer/rv for some time, but after Harvey hit, I realized I wanted something a bit more robust, that would fit my family better if/when we need to evacuate the area. I purchased an old school bus and have started the conversion process a little bit each weekend and when I have spare time. I plan on adding a solar system to run the "house" electrical system, and have started purchasing equipment for that when I find a good deal. Although I have taken a few electrical classes in the course of my engineering degree, I am more mechanically minded, and was looking for those more versed than I am with Ohm's law.
    I look forward to learning a lot from this forum.
    ~Alf
    ~Alf
  • #2
    I suggest researching the systems commonly used by RVers. In general this involves an extra deep discharge
    battery with a battery isolator, and a generator for heavy stuff. Use propane for big heat stuff. Solar is not going
    to be a primary source. Bruce Roe
    • #3
      Thank you, I plan to run all my heating/cooking needs from propane or diesel. I am planning on running about 1000w of PV panels, and I keep going back and forth between 12v and 24v for the battery bank. If I go 12v, I can charge off the alternator as well, but I know 24v would allow thinner wiring. I already have the panels, and an unfortunately oversized 12v inverter which I may sell. Lots of good information and knowledgeable folks in this forum.
      Thanks,
      ~Alf
      ~Alf
      • #4
        Be smart and whichever fuel you decide upon is also used for a Generator. LPG would likely be a better choice especially on the gulf coast.
