Hi All. My first post, new at this.. I'm down in Baja and it's very hard to find someone to help with technical issues. I have a major problem with my battery bank.
I have a 24 volt, 2300 watt panel array feeding 10 'Data Safe" 96ah batteries and a cheap Ebay Chinese 8000 watt inverter. The issue is the batteries will not equalize. In the morning one side of the battery bank will read say 13 volts and the other side of the pair will be in the 11.5v range (dead!) I suspect I've got several bad cells in the bank but am having trouble isolating them... I have removed the batteries at full charge isolated all of them and watch for voltage drops, one dropped immediately and I replaced it. The problem persists. On top of this recently I had one battery get very hot (boiling)... I removed it for the day but it holds a charge so I put it back in the bank... Also worth mention is that I didn't wire the system. I purchased it as a pre made kit; 4 batteries in a crate with inverter and charge controller and 6 outside...
Thanks for any help
Thanks for any help
