Hi guys my question is I run a 12/24vdc fridge off 2 solar panels with 2. 12v batteries I also run 5 panels to a 24 v setup ...can I run the fridge and the 2 panels directly to batteries onmy 24 v setup just to save on batteries your advice is greatly appreciated
Most Popular Content
Solar fo fridge
At the moment I have 2 12v batteries running fridge and 4 12v batteries running the rest of my camp -
If you have an actual 12/24v refrigeration unit. It will operate very nice on 24v, it will use half the amps and run a much shorter cycle. You will be glad you did, and wonder why you didn't to being with.Comment
You're not clear on what you want to do. So I'll guess
Running 2 arrays and charge controllers to 1 battery bank is doable as long as they are total within the charging specifications of the battery bank..
Adding the 2 batteries to the 4 batteries to create 1 bank will decrease battery life. Not good to mix new/old or different size batteries and multiple strings are not good for keeping the batteries balance.
WWWComment
