solar water pumps 220 volt 1200 watt
solar pumping
Hi, if the electric motor can be supplied with three phase 220 Vac, you can use a VFD.
The only problem is that will need a lot of solar panels to achieve the voltage and the watts required to do so.
With the VFD there is the possibility to program a simple MPPT follower, using a trimmer and a signal from the solar panels.
If not, just read the other threads, use a DC system, there a lots of manufacturers that sell them.
RegardsComment
