hello,
i am planning to cycle/filter water in my duck pond. i found a dc submersible pump with the following specs:
volts - 12dc
amps - 1000mA
head - 5m
flow - 500 L/h (at zero)
power - 12W
i would like to go direct solar with this and simply pump when the sun shines. that said and given these specs:
1. what size panel would you recommend?
2. i suppose i should have a voltage regulator between panel and pump? any recommendations?
3. any other panel or regulator or design advice is much appreciated
thanks
volts - 12dc
amps - 1000mA
head - 5m
power - 12W
thanks
